vcBufferProductsStatement
Buffer statement creates a temporary storage for products in a grid pattern. Multiple products can be coming in and leaving the buffer in parallel. Transport of products is handled similarly to the Transport statements. The statement continues execution until the break condition is met and the buffer has emptied.
BreakConditionPropertyvcExpressionPropertyR
Access expression value via vcExpressionProperty, E.g., BreakConditionProperty.Value
Gets a property which defines when this expression evaluates to True (at least once), the buffer stops accepting products.
This allows the buffer to empty and then the statement execution to end. The expression is evaluated at the start of the statement execution and every time a product arrives to or leaves the buffer. Must be from the same component.
BufferModevcBufferModeRWGets or sets the product access order of the buffer.
DestinationvcTransportOutTypeRWGets or sets the destination to where products leave the buffer.
DestinationContainervcContainerRWGets or sets the component container whose output connection is used to place the outgoing products. Only used when Destination is set to vcTransportOutType.CONTAINER.
DestinationTransportNodevcTransportNodeRWGets or sets the destination transport node. Only used when Destination is set to vcTransportOutType.TRANSPORT_NODE.
FiltervcProductFilterRGets the filter.
InputResourcePositionFramevcFrameFeatureRWGets or sets the resource position offset from product position and XY plane on which resource position is projected to while emptying the buffer.
This allows the resource position to move along with the product position but still remain on a certain plane. Must be from the same component.
OffsetvcMatrixRWGets or sets the offset of the first product from product position frame.
OutputResourcePositionFramevcFrameFeatureRWGets or sets the resource position offset
from product position and XY plane on which resource position is projected to for transport out operations.
ParallelInputLimitIntegerRWGets or sets how many products can be arriving to the buffer in parallel. Must be greater than zero.
ParallelOutputLimitIntegerRWGets or sets how many products can be leaving the buffer in parallel. Must be greater than zero.
PatternCountrVectorRWGets or sets the number of buffer slots per X,Y,Z axis.
The Real values of the vector are rounded to nearest Integer values. Each dimension should in inclusive range 0 to 1289.
PatternStepvcVectorRWGets or sets the step between products in pattern per X,Y,Z axis.
PatternTotalCountIntegerRGets the total count of patterns.
ProductPositionFramevcFrameFeatureRWGets or sets the frame defining the position and orientation of the product pattern in combination with the Offset property. Must be from the same component.
ReservedProductVariableNameStringRWGets or sets the name of variable containing products already reserved using Reserve Product statement.
The buffer will be first filled using these products and then will continue to receive further products as defined by the Source property.
SourcevcTransportInTypeRWGets or sets how products get into the buffer.
demoteFromCombinationFiltervcProductFilterNoneDowngrades back to filter, filter count must have 1 or 0 filters.
vcProductFilter: The modified filter.
TypeError: When the filter is not a CombinationFilter.
TypeError: When CombinationFilter has more than 1 sub-filters.
promoteToCombinationFiltervcProductFilterNoneUpgrades current filter to combination filter.
TypeError: When the filter is already a CombinationFilter.
replaceFromvcProductFiltervcStatement statementSets filter from other container.
statement (vcStatement): The statement to replace the filter from. Has to be a statement with a filter container.
AttributeError: When argument is a statement without a filter container.
setFiltervcProductFiltervcProductFilterType filterTypeSets to specific filter.
filterType (vcProductFilterType): The type of filter to set to.
vcProductFilter: The new filter.
AttributeError: When the argument filterType is ProductType.
NameParametersDescription
OnFilterChangedNoneTriggered when filter is changed.
